Hola a todos. Pues mi problema es que no puedo grabar una peli que tengo de 7 GB en un dvd de doble capa claro, pues ya he quemado tres discos y no lo consigo, tengo de sistema el vista y el programa para grabar el nero 9 y mi grabadora si admite discos de doble capa, os copio el registro que hace nero para haber si podeis ver el problema, saludos.
REGISTRO DE NERO:
Windows Vista 6.0
IA32
WinAspi: -
NT-SPTI used
Nero Version: 9.2.6.100
Internal Version: 9, 2, 6, 100
(Nero Express)
Recorder: <TSSTcorp DVD+-RW TS-H653B>Version: D200 - HA 1 TA 1 - 9.2.6.100
Adapter driver: <****** ATA> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD-ROM: <TSSTcorp DVD-ROM TS-H353B>Version: D200 - HA 1 TA 0 - 9.2.6.100
Adapter driver: <IDE> HA 1
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
TSSTcorp DVD-ROM TS-H353B E: CdRom0
TSSTcorp DVD+-RW TS-H653B F: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2045MB (2094544kB)
Free physical memory: 1320MB (1352508kB)
Memory in use : 35 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
4.11.2009
Compilación UDF/ISO
18:45:30 #1 Text 0 File SCSIPTICommands.cpp, Line 452
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
18:45:30 #2 Phase 112 File dlgbrnst.cpp, Line 1767
DVD-Video files reallocation started
18:45:31 #3 Text 0 File DVDVideoCompilation.cpp, Line 622
Content of VIDEO_TS.IFO has been modified
18:45:31 #4 Text 0 File DVDVideoCompilation.cpp, Line 622
Content of VIDEO_TS.BUP has been modified
18:45:31 #5 Phase 113 File dlgbrnst.cpp, Line 1767
DVD-Video files reallocation completed
18:45:31 #6 Text 0 File Isodoc.cpp, Line 6940
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
18:45:31 #7 Phase 111 File dlgbrnst.cpp, Line 1767
DVD-Video files sorted
18:45:31 #8 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
18:45:31 #9 ISO9660GEN -11 File Geniso.cpp, Line 3349
18:45:31 #10 Text 0 File Burncd.cpp, Line 3587
Turn on Disc-At-Once, using DVD media
18:45:31 #11 Text 0 File DVDPlusDualLayer.cpp, Line 1424
SetDriveCaps: Set LAST LBA of layer 1 to 2051039
18:45:31 #12 ISO9660GEN -11 File Geniso.cpp, Line 3349
18:45:31 #13 ISO9660GEN -11 File Geniso.cpp, Line 3349
18:45:31 #14 Text 0 File DlgWaitCD.cpp, Line 313
Last possible write address on media: 4173823
Last address to be written: 4021903
18:45:31 #15 Text 0 File DlgWaitCD.cpp, Line 325
Write in overburning mode: NO (enabled: CD)
18:45:31 #16 Text 0 File DlgWaitCD.cpp, Line 2882
Recorder: TSSTcorp DVD+-RW TS-H653B, Media type: DVD+R DL
Disc Manufacturer ID: <MKM>, Media Type ID: <003>, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
18:45:31 #17 Text 0 File DlgWaitCD.cpp, Line 500
>>> Protocol of DlgWaitCD activities: <<<
18:45:31 #18 Text 0 File ThreadedTransferInterface.cpp, Line 744
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 4021904 (4021904) = #4021904/893:45.29
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4021904 blocks [F: TSSTcorp DVD+-RW TS-H653B]
18:45:31 #19 Text 0 File ThreadedTransferInterface.cpp, Line 946
Prepare [F: TSSTcorp DVD+-RW TS-H653B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 8236859392, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 4021904 | 0 | 0x00
4021904 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
18:45:31 #20 Text 0 File SCSIPTICommands.cpp, Line 242
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
18:45:31 #21 Text 0 File Burncd.cpp, Line 4320
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
18:45:31 #22 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
18:45:31 #23 Text 0 File Burncd.cpp, Line 4442
Cache writing successful.
18:45:31 #24 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
18:45:32 #25 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11.080 KB/s)
18:45:32 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2676
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:45:32 #27 Text 0 File DVDPlusDualLayer.cpp, Line 1883
GetDriveCaps: LAST LBA of layer 1 is 2051039
18:46:19 #28 SPTI -1066 File SCSIPassThrough.cpp, Line 215
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0xAD 00 00 00 00 00 00 21 08 04 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 24
Buffer x03fcf940: Len x804
18:46:19 #29 Text 0 File DVDPlusDualLayer.cpp, Line 1424
18:46:19 #30 Text 0 File DVDPlusDualLayer.cpp, Line 1883
18:46:19 #31 Text 0 File DVDPlusDualLayer.cpp, Line 757
L0 Data Zone Capacity set to 2051040 (1F4BE0h, 4005MB) -> OK, confirmed setting
18:46:19 #32 CDR -1205 File DVDPlusDualLayer.cpp, Line 784
Burning Layer 1
18:46:19 #33 Text 0 File DVDPlusDualLayer.cpp, Line 794
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
18:46:19 #34 Text 0 File Cdrdrv.cpp, Line 9966
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R DL (14), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: FCFFFF h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: MKM.....
Media type ID: 003
Number of Physical format information bytes in use in ADIP up to byte 63: 64
Media Specific [16..783]:
00 00 03 4D 4B 4D 00 00 - 00 00 00 30 30 33 00 40 ...MKM.....003.@
25 25 37 0C 02 2D 66 02 - 2D 66 21 23 0D 0E 14 14 %%7..-f.-f!#....
02 01 01 10 00 21 23 0D - 0E 14 14 02 01 01 10 00 .....!#.........
04 00 33 7B 5C 02 2B 64 - 2E 28 1C 0A 0A 20 02 01 ..3{\.+d.(......
01 00 02 69 63 2E 2A 1C - 0C 0C 20 03 02 01 00 72 ...ic.*........r
84 00 02 53 67 2E 28 1C - 0A 0A 20 02 01 01 00 00 ...Sg.(.........
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 00 00 0
18:46:19 #35 Text 0 File Cdrdrv.cpp, Line 9966
Media type ID: 003
00 00 00 0
18:46:19 #36 Text 0 File Cdrdrv.cpp, Line 9966
Media type ID: 003
00 00 00 0
18:46:19 #37 Text 0 File DVDR.cpp, Line 7745
Drive: TSSTcorp DVD+-RW TS-H653B
Book Type request [TSST]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
18:46:19 #38 CDR -1207 File DVDR.cpp, Line 5929
Book Type automatically set to: DVD-ROM
18:46:19 #39 Text 0 File DVDPlusRW.cpp, Line 637
Start write address at LBA 0
DVD high compatibility mode: Yes
18:46:19 #40 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
18:53:49 #41 CDR -1206 File DVDPlusDualLayer.cpp, Line 2181
Burning Layer 2
18:53:49 #42 Text 0 File DVDPlusDualLayer.cpp, Line 2190
Perform layer 1 to 2 jump before writing at address 2051040 (1F4BE0h)
18:54:16 #43 SPTI -1135 File SCSIPassThrough.cpp, Line 215
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1135)
CDB Data: 0x2A 00 00 1F 4E 60 00 00 20 00 00 00
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x19e23600: Len x10000
0x00 00 01 BA 44 00 1E 07 0D F5 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 86 06 92 93 BB 66 5F 60 84
0xE2 48 1E FB F2 2D B3 A6 CC 00 5C 00 A4 0A 00 98
18:54:16 #44 CDR -1135 File Writer.cpp, Line 306
Write error
18:55:12 #45 Text 0 File DVDPlusRW.cpp, Line 904
EndDAO: Last written address 2051680
18:55:12 #46 Text 0 File Cdrdrv.cpp, Line 9966
End Physical Sector Number of Data Area: 224BBD h
Media type ID: 003
00 00 00 00 00 00 00 00 - 00 03 00 00 00 22 4B BD ............."K.
00 00 00 0
18:55:12 #47 Text 0 File DVDR.cpp, Line 7745
Book Type request [TSST]: DVD+R DL
18:55:12 #48 CDR -1176 File WriterStatus.cpp, Line 292
Session fixation error
18:55:12 #49 TRANSFER -24 File WriterStatus.cpp, Line 292
Could not perform end of Disc-at-once
18:55:12 #50 Text 0 File DVDPlusDualLayer.cpp, Line 1424
SetDriveCaps: Set LAST LBA of layer 1 to 0
18:55:13 #51 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 8x (11.080 KB/s)
18:55:13 #52 Text 0 File SCSIPTICommands.cpp, Line 289
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
18:55:16 #53 Text 0 File Cdrdrv.cpp, Line 11243
DriveLocker: UnLockVolume completed
18:55:16 #54 Text 0 File SCSIPTICommands.cpp, Line 452
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
REGISTRO DE NERO:
Windows Vista 6.0
IA32
WinAspi: -
NT-SPTI used
(Nero Express)
AutoRun : 1
Excluded drive IDs:
BUFE : 0
4.11.2009
Compilación UDF/ISO
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Revision : 1.02
Joliet : FALSE
DAO infos:
MCN: ""
DAO layout:
Sense Code: 0x24
Sense Qual: 0x00
Burning Layer 1
Media type ID: 003
00 00 00 0
Media type ID: 003
00 00 00 0
Media type ID: 003
00 00 00 0
Burning Layer 2
Sense Code: 0x0C
Sense Qual: 0x00
Write error
Media type ID: 003
00 00 00 0
Existing drivers:
Registry Keys:
