b3n0x
Descarga directa:http://download.utorrent.com/beta/utorrent-2.0-beta-16081.upx.exe
* We've added UDP tracker support!
* uTP has been improved significantly over the previous alpha, with many bugs fixed and performance improvements. It's no longer hidden in Advanced settings.
* The setup dialog has been overhauled to make it much easier to use and with a built-in speed test. It's still not quite complete yet, but this will give you a good taste of what we're up to with it!
* Transfer caps are now configurable, with usage tracking and graphs.
* Change: disable toolbar offers for Wine installs
* Feature: New Setup guide & Speedtest.
* Change: uninstaller is added to all user profiles
* Fix: crash when assigning new label to torrents from RSS
* Change: Incomplete downloads sort after completed downloads if sorting by "Completed On"
* Feature: Add Moldova to peer flags
* Change: Added upnp host cache to speed up upnp nat resolution on misbehaving routers
* Fix: maintain category list selection on update for some edge cases
* Change: if selected, install start menu and desktop shortcuts to all users instead of only current user
* Feature: Grayscale disabled toolbar buttons
* Fix: fixed uTP selective ack bug (would cause connections to stall and time out)
* Fix: fixed uTP fast re-send bug (would sometimes re-send packets that shouldn't be re-sent)
* Change: prompt to take associations in installer only if any others exist
* Fix: buffer overrun vulnerability in create torrent dialog
* Fix: uTP recovers faster after timeout
* Feature: uTP supports window sizes smaller than the packet size
* Change: reduced uTP overhead slightly by ramping up packet sizes at lower rates
* Feature: enable and disable toolbar buttons according to selected torrents
* Change: UAC must be completed to install in Vista or higher
* Fix: memory leaks in main window, protocol associations, settings dialog, general tab
* Change: Tweaks to Ask toolbar offer
* Feature: UDP tracker support
* Fix: only change run on startup if installer is shown
* Change: added support for 3:rd party applications to more easily be configured to access the uTorrent web UI, i.e. to pair the applications
* Fix: make "alternate upload rate when seeding" apply when the seeding is set by the scheduler
* Fix: align "Web Seeds" in torrent creation dialog
* Fix: translated strings in uninstaller
* Fix: http seeds would not reconnect after stopping and starting torrent
* Fix: http seed for multifile torrents
* Fix: regression in 15562 that caused frequent crashes
* Feature: New installer with EULA, file association
* Fix: uTP issue on low-latency high-throughput networks
* Fix: copying long filenames to clipboard no longer results in garbage or crash
* Fix: fixed web seed support for multi-file torrents
* Change: torrent whose "Force Recheck" is greyed out will not recheck when asked through multi-torrent selections
* Fix: when adding torrents through URLs via commandline, we would always open the add torrent dialog
* Fix: handle multi file torrents with web seed urls that incorrectly don't end with a slash
* Fix: make sure web seed urls end with a slash for multifile torrents
* Fix: setup Vista firewall
* Fix: remove settings on Vista during un-installation
* Feature: New "Transfer Cap" pane in Preferences
* Feature: uTP can be enabled or disabled using "Enable bandwidth management" checkbox in Preferences
* Fix: Check at startup for incompatible versions of NVIDIA nForce firewall
s4lu2
s4lu2
