La memoria con overclocking DDR4 CORSAIR VENGEANCE RGB PRO Series ilumina el PC con un efecto hipnótico gracias a la iluminación RGB dinámica multizona, además de ofrecer las mejores características de las DDR4 en cuanto a rendimiento.
PRECIO ANTERIOR: 119,99
PRECIO ACTUAL: 84,99
COMPRALO AQUI: https://www.corsair.com/es/es/p/mem...d-ryzen-memory-kit-a-black-cmw32gx4m2z3600c18
Fan Included | No |
Memory Color | BLACK |
Memory Compatibility | Intel 300 Series,Intel 400 Series,Intel 500 Series,Intel 600 Series,Intel 400 Series,Intel 500 Series,Intel 600 Series,AMD X570 |
Memory Detail Compatibility | Intel 300 Series,Intel 400 Series,Intel 500 Series,Intel 600 Series,Intel 400 Series,Intel 500 Series,Intel 600 Series,AMD X570 |
Heat Spreader | Anodized Aluminum |
LED Lighting | RGB |
Memory Series | VENGEANCE RGB PRO |
Memory Size | 32GB (2 x 16GB) |
Memory Type | DDR4 |
Package Memory Format | DIMM |
Package Memory Pin | 288 |
Performance Profile | XMP 2.0 |
SPD Latency | 18-18-18-43 |
SPD Speed | 2666MHz |
SPD Voltage | 1.2V |
Tested Latency | 18-22-22-42 |
Tested Speed | 3600 MT/s |
Tested Voltage | 1.35 |
Interface | DDR4 |
Single / Multi-Zone Lighting | Dynamic MultiZone |
Weight | 0.16 |
