El CORSAIR 4000D AIRFLOW es un chasis ATX semitorre distintivo, optimizado para disponer de un elevado caudal de aire, con una sencilla gestión del cableado y dos ventiladores CORSAIR AirGuide de 120 mm incluidos para que la refrigeración sea excepcional.
Antes 119,9, ahora 74,9 euros. Compralo aqui: https://www.corsair.com/es/es/p/pc-...-glass-mid-tower-atx-case-black-cc-9011200-ww
Case Height | 466 |
Case Length | 453 |
Case Width | 230 |
Case Form Factor | MID TOWER |
Case Motherboard Support | Mini-ITX | MicroATX | ATX | E-ATX (305mm x 277mm) |
Color | BLACK |
Weight | 9.15 |
Radiator Compatibility | 120mm, 140mm, 240mm, 280mm, 360mm |
Maximum GPU Length | 360 |
Maximum CPU Cooler Height | 170 |
Maximum PSU Length | 220 |
Compatible Liquid Coolers | H55, H60, H75, H80i, H90, H100i, H105, H110i, H115i, H150i |
Case Size | NA |
Case Material | Steel, Tempered Glass, Plastic |
Case Dimensions | 453mm x 230mm x 466mm |
Case Power Supply | ATX |
Case Expansion Slots | 7 vertical + 2 horizontal |
Case Drive Bays | (x2) 3.5in (x2) 2.5in |
Case Front IO | (1x) USB 3.1 Type C, (1x) USB 3.0, (1x) Audio in/out |
Case Window | Tempered Glass |
Case Warranty | 2 Year |
Internal 3.5" Drive Bays | 2 |
Internal 2.5" Drive Bays | 2 |
