follow_along_with_video_below_to_see_how_to_install_our_site_as_web_app
Se debe tener en cuenta: this_feature_currently_requires_accessing_site_using_safari
Hola Carlos57, exactamente que tipo de error te da? Saludos
Carlos
UGAZIO
1K22-0867-0795-66M4-5816-4208-****
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 8.1.1.0
Internal Version: 8, 1, 1, 0
(Nero Express)
Recorder: <PIONEER DVD-RW DVR-112D>Version: 1.21 - HA 1 TA 0 - 8.1.1.0
Adapter driver: <IDE> HA 1
Drive buffer : 2000kB
Bus Type : default
CD-ROM: <PIONEER DVD-RW DVR-112D>Version: 1.21 - HA 1 TA 0 - 8.1.1.0
=== Scsi-Device-Map ===
CdRomPeripheral : PIONEER DVD-RW DVR-112D atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1600AABS-00PRA0 nvata Port 2 ID 0 DMA: Off
DiskPeripheral : WDC WD3200AAJS-00B4A0 nvata Port 3 ID 0 DMA: Off
CdRomPeripheral : XON NS9AZ0D 1.03 a0xtniep Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-112D F: CdRom0
XON NS9AZ0D G: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095596kB)
Free physical memory: 1229MB (1258756kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
29.11.2008
CD-ROM (ISO)
21:05:59 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
21:05:59 #2 Text 0 File Isodoc.cpp, Line 6671
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
21:05:59 #3 Text 0 File Burncd.cpp, Line 3212
Protección contra insuf. datos activado
21:05:59 #4 ISO9660GEN -11 File Geniso.cpp, Line 3347
First writeable address = 0 (0x00000000)
21:05:59 #5 Text 0 File Burncd.cpp, Line 3530
Turn on Track-At-Once, using CD-R/RW media
21:06:01 #6 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorCD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
21:06:02 #7 Text 0 File ThreadedTransferInterface.cpp, Line 1057
Removed 2 run-out blocks from end of track 1. Length: 165763 -> 165761.
21:06:02 #8 Text 0 File ThreadedTransferInterface.cpp, Line 1057
21:06:03 #9 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 165762 ( 36:52.12)
21:06:03 #10 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
21:06:03 #11 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: PIONEER DVD-RW DVR-112D;
CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd.
ATIP Data:
Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
21:06:03 #12 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
21:06:03 #13 Text 0 File ThreadedTransferInterface.cpp, Line 785
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 165763 (165763) = #165763/36:50.13
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 165761 blocks [F: PIONEER DVD-RW DVR-112D]
21:06:05 #14 Text 0 File ThreadedTransferInterface.cpp, Line 986
Prepare [F: PIONEER DVD-RW DVR-112D] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 339789824, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 165763 | 0 | 0x00
165763 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
21:06:05 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1057
21:06:05 #16 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
21:06:05 #17 Text 0 File Burncd.cpp, Line 4316
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
21:06:05 #18 Phase 24 File dlgbrnst.cpp, Line 1764
Caching of files started
21:06:05 #19 Text 0 File Burncd.cpp, Line 4435
Cache writing successful.
21:06:05 #20 Phase 25 File dlgbrnst.cpp, Line 1764
Caching of files completed
21:06:05 #21 Phase 36 File dlgbrnst.cpp, Line 1764
Burn process started at 40x (6.000 KB/s)
21:06:05 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2735
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
21:06:05 #23 Text 0 File MMC.cpp, Line 22430
Set BUFE: Buffer underrun protection -> ON
21:06:05 #24 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
21:06:06 #25 Text 0 File Cdrdrv.cpp, Line 1367
21:06:06.031 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:19 #26 Text 0 File Cdrdrv.cpp, Line 1367
21:06:19.937 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:19 #27 Text 0 File Cdrdrv.cpp, Line 1367
21:06:19.953 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:19 #28 Text 0 File Cdrdrv.cpp, Line 1367
21:06:19.984 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #29 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.000 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #30 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.031 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #31 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.062 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #32 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.078 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #33 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.109 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #34 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.125 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #35 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.156 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #36 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.171 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #37 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.203 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #38 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.218 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #39 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.281 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #40 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.296 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #41 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.328 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #42 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.343 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #43 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.375 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #44 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.390 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #45 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.421 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #46 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.437 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #47 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.468 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #48 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.500 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #49 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.515 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #50 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.546 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #51 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.593 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #52 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.609 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #53 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.640 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #54 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.671 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #55 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.687 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #56 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.718 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #57 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.734 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #58 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.765 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #59 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.781 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #60 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.812 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #61 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.828 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #62 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.859 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #63 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.906 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #64 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.937 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #65 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.953 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:20 #66 Text 0 File Cdrdrv.cpp, Line 1367
21:06:20.984 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #67 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.000 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #68 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.031 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #69 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.046 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #70 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.078 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #71 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.093 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #72 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.125 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #73 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.156 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #74 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.171 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #75 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.234 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #76 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.250 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #77 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.265 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #78 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.296 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #79 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.312 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #80 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.343 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #81 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.359 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #82 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.390 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #83 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.421 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #84 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.437 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #85 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.468 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #86 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.484 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #87 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.546 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #88 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.562 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #89 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.578 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #90 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.609 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #91 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.625 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #92 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.656 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #93 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.687 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #94 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.703 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #95 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.734 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #96 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.750 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #97 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.781 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #98 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.796 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #99 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.859 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #100 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.875 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #101 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.890 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #102 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.921 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #103 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.937 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:21 #104 Text 0 File Cdrdrv.cpp, Line 1367
21:06:21.968 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #105 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.000 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #106 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.015 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #107 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.046 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #108 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.062 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #109 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.093 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #110 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.109 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #111 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.171 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #112 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.187 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #113 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.203 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #114 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.234 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #115 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.250 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #116 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.281 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #117 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.312 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #118 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.328 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #119 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.359 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #120 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.375 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #121 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.406 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #122 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.421 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #123 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.484 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:06:22 #124 Text 0 File Cdrdrv.cpp, Line 1367
21:06:22.500 - 㩆倠佉䕎剅䐠䑖刭⁗䐠剖ㄭ㈱D : Queue again later
21:07:54 #125 Text 0 File MMC.cpp, Line 17189
<PIONEER DVD-RW DVR-112D> start Close Track #2
21:07:56 #126 SPTI -1176 File SCSIPassThrough.cpp, Line 181
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1176)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x51 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x71 00 05 00 00 00 00 0E 00 00 00 00 72 03
Buffer x04cae000: Len x20
21:07:56 #127 CDR -1176 File ThreadedTransferInterface.cpp, Line 1233
Session fixation error
21:07:56 #128 Text 0 File MMC.cpp, Line 17189
21:07:58 #129 SPTI -1176 File SCSIPassThrough.cpp, Line 181
Sense Code: 0x72
Sense Qual: 0x03
21:07:58 #130 CDR -1176 File ThreadedTransferInterface.cpp, Line 1233
21:07:58 #131 Phase 38 File dlgbrnst.cpp, Line 1764
Burn process failed at 40x (6.000 KB/s)
21:07:58 #132 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
21:08:02 #133 Text 0 File Cdrdrv.cpp, Line 11276
DriveLocker: UnLockVolume completed
21:08:02 #134 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
