  2. Con el fin de ofrecerle una experiencia de navegación adaptada a sus necesidades le informamos de que esta web utiliza cookies. Puede deshabilitarlas en las opciones de su navegador web. Mas info Politica de Cookies Free data recovery software
Nuevo buque insignia de PIONEER PRO-DJ MEP-7000 y SEP-C1
Tema en 'El Hardware de tu PC' iniciado por XALIAS, 23 Sep 2008.
  1. XALIAS
    XALIAS New Member
    1 Oct 2007
    1.083
    Me Gusta recibidos:
    0
    Puntos:
    0
    Bien viendo la pagina de PIONEER por razones Tecnicas, he descargado el Catalogo Oficial del mismo, y he encontrado nuevos aparatos de PIONEER dentro de su linea PRO-DJ. Mas concretamente son los PIONEER MEP-7000 y SEP-C1.
    [​IMG]
    Son Unos controladores via USB Software y Reproductores de CD-MP3, se puede encontrar en dos versiones:
    MEP-7000 Controlador + Unidad de CD/USB-MP3 + DJ software “DJS”. por $2,299.
    SEP-C1 Controlador + DJ software “DJS”. por $1,199.
    Navegando por la WWW he encontrado sus especifficaciones tecnicas (En Ingles)
    MEP-7000 is a system product composed of control unit, drive unit (CD/USB playable) + DJ software “DJS”.
    SEP-C1 is a system product composed of control unit + DJ software “DJS”.
    PIONEER is a registered trademark of Pioneer Corporation.
    Serato is a registered trademark of Serato Audio Research
    1 MPEG-1 Audio Layer3, MPEG-2 Audio Layer3 LSF. Also capable of playing MP3 file stored on a device connected to a PC.
    2 Available only on USB storage device (USB memory, HDD, etc.) WAV/AIFF recorded on a disc media cannot be played.
    3 Using firmware version 1.6000, the MEP-7000 can control Pioneer DJS. Further firmware updates will be available online.
    4 Support for more DJ software applications pending from other companies but Pioneer does not guarantee the performance of software on users’ computers. Scratch LIVE is a registered trademark of Serato Audio Research.
    5 BUBBLE: Simulates a “flare”-type scratch performed on a turntable. TRANS: A transform-effect which rhythmically cuts the audio.
    6 JET: A flanging effect similar to an offset playback using two analog records. ROLL: Looping effect with pitch variation based on jog rotation. WAH: Variable frequency cut-off according to the rotation of jog dial.
    7 As of January 16, 2008, according to Pioneer.
    8 WIDE mode not be available on MP3/AAC/WAV/AIFF.
    9  Depending on a computer specifications, it may occasionally be necessary to use provided auxiliary power cable.
    SPECIFICATIONS:
    MEP-7000 SEP-C1
    ●Control Unit●
    USB Terminal USB B terminal x 1
    Video Output Terminal MONITOR OUT(RCA)
    Power Requirements - USB bus power*9
    Dimensions(without package) 483 mm (W) × 84 mm (D) × 133 mm (H)
    Weight(without package) 1.7 kg
    ●Drive Unit●
    Compatible Media Music CD, CD-R, CD-RW, DVD±R, DVD±RW,
    DVD±R-DL, USB storage device (USB memory, etc) -
    Compatible File MP3, AAC, WAV (44.1 kHz 16 bit), AIFF (44.1 kHz 16 bit) -
    File System responding to USB storage FAT12, FAT16, FAT32, HFS+ -
    Frequency Response 4 Hz - 20 kHz -
    Signal-to-Noise Ratio 115 dB or more(JEITA) -
    Total Harmonic Distortion 0.006 % or less (JEITA) -
    USB Terminal USB A terminal x 2、USB B terminal x 1 -
    Audio Output Terminal AUDIO OUT x 2 (RCA), DIGITAL OUTx2 (RCA) -
    Other Terminals CONTROL x 2 (3.5 mm mini plug), Remote Control -
    Audio Output Voltage 2V RMS -
    Power Requirements AC 120V 60Hz -
    Power Consumption 32 W -
    Dimensions(without package) 483 mm (W) ×325 mm (D) ×91 mm (H)
    19.01 x 12.79 x 3.58 inch 483 mm (W) × 84 mm (D) × 133 mm (H)
    19.01 x 3.30x 5.23 inch
    Weight(without package) 6.1 kg
    13.44 lbs 1.7 kg
    3.74 lbs
    ●DJ Software “DJS”●
    Compatible OS Windows Vista/XP/2000*1
    Compatible File MP3
    【Required System】
    CPU Pentium-M 1.5 GHz or better
    Memory 512 MB or more (Windows Vista: 1GB or more)
    HDD 250 MB or more
    Disc Drive CD-ROM / CD-DA playable
    Display 1024 pixel x 768 pixel (XGA) or more,
    And High Color (16 bit or more)
    Sound Card Sound card with 2 or more terminals or external sound device
    Mas imagenes del Bicho:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Dejo unos Videos del aparato:
    [YOUTUBE]1EynaKTUHwo[/YOUTUBE]
    [YOUTUBE]Rq4G34gWbok[/YOUTUBE]
    Salu2.
    Última edición: 23 Sep 2008
  2. razor
    razor Administrador Global del Foro Miembro del Staff Administrador
    14.659
    Me Gusta recibidos:
    20
    Puntos:
    60
    Joer, vaya bicho. Se podran hacer virguerias con el...
Compartir esta página
